Activity Forums Apple Final Cut Pro Legacy wear and tear to camera from capturing?
  • wear and tear to camera from capturing?
    Posted by Jason O’hara on December 1, 2010 at 10:11 pm
    My primary camera, NOT the one I usually use for capturing, is due for 2 part replacements: 1. the sub-assembly (which I understand to be the tape mechanism) and 2. the Drum Assembly (containing new tape heads) I have a ton of HDV material to capture and was wondering if I should use this camera to do all the capturing before taking it in for the repairs – essentially running these parts into the ground and saving the wear and tear on the other camera I usually use for capturing.
    Am I right to assume these are the main components that would suffer the wear and tear from the capture process or are there others?
    Any advice is appreciated, Thanks
    Andrew Rendell replied 15 years, 9 months ago 2 Members · 1 Reply
  • Andrew Rendell
    December 2, 2010 at 5:30 pm
    Personally, I wouldn’t take that kind of risk with my tapes if I knew the tape mechanism was on the way out. Also, if I had a ton of HDV tapes, I’d get a cheap HDV deck like the Sony HVR-M15 just for capturing rather than use a camcorder to do it (whether it’s financially efficient rather depends on how many tapes you’ve got but if it’s a lot it probably is).
