Activity › Forums › Adobe After Effects › Weak Motion Blur
  • Weak Motion Blur
    Posted by Revslide on May 18, 2006 at 10:49 am
    I have created a composition with motion blur(with layer checked) and exported it as a quicktime movie. The end result was a very weak motion blur and was a great difference from my comp preview window. Most of my AE settings as set as default and i had no such problems before. Can anyone advise me on what could be the cause of it? Thank you!
    Revslide replied 20 years, 4 months ago 3 Members · 4 Replies
  • Mylenium
    May 18, 2006 at 12:00 pm
    Maybe you used a different background color while working and then rendered your clip out with Alpha (which in external viewers will show up against a black background and appear much weaker though the motionblur is calculated correctly). Other than cranking up the shutter angle, I can’t think of a thing to make it more pronounced.
    Mylenium
    [Pour Myl
  • David Bogie
    May 18, 2006 at 10:36 pm
    This has been crossposted to other AE forums. Please do us the favor of compiling the answers you have received and telling us what helped.
    bogiesan
  • Revslide
    May 19, 2006 at 4:16 am
    I realised that my
  • Revslide
    May 19, 2006 at 4:22 am
    Sorry for cross-posting as I was meeting a project deadline and needed to solve the problem urgently.
    Anyway these are the solutions offered to me;
    If you render an interlaced output the amount of MB is effectively halved by the “doubled” frame rate of interlaced images, compared to the non-interlaced preview. Try increasing the shutter size in Comp Settings if you are unhappy with the amount of MB. – Andrew Yoole from Adobe Forums
    You can change/adjust the motion blur settings in AE by going into the
