Activity Forums Adobe After Effects wazelwusel or anyone a question
  • wazelwusel or anyone a question
    Posted by Bill Hash on April 26, 2007 at 5:36 am
    Well i really was taken to task for some recent questions on importing tga fileas
    This should be the last one for this project I had an animator make an animation for me in 3dmax as tga files I have unzipped them and brouight them into my project but I realize the 14 zipped files now unzipped and numbered sequentially in my project window would be better as one large file (1445 tga frames)
    My problem as I see it is under the current setup trying to place the 14 files on a composition timeline all prperly positioned to play out before rendering this comp intoan avi
    the next comp withthis completed avi I will be putting some text and titles into along with the soundtrack so any advice ??
    How to combine the 14 seperate tga files for ease of putting on to comp timeline many thanks
    Danny Princz replied 19 years, 4 months ago 3 Members · 2 Replies
  • Michael Duff
    April 26, 2007 at 6:11 am
    when you import the targa sequence … go File->Import, then select the first one, and then select the check box there labelled “auto detect sequence” or something like that. Then AE should import them all as one clip.
    is this what you mean?
  • Danny Princz
    April 26, 2007 at 12:18 pm
    in the project window select the 14 targa sequences, drag them to the new comp button.
    select single com, check sequence layers, make sure overlap is unchecked.
    then use this comp as your master footage layer in whatever else you are doing
    who is that masked man…
    https://www.exposedideas.com/
