Activity Forums Adobe After Effects Expressions Way to view all expressions in AE project?
  • Way to view all expressions in AE project?
    Posted by Dan Simmonds on February 6, 2012 at 3:57 pm
    Hi people,
    First off thanks for a great forum, this has been a massive help in my noob after effects projects!
    Is there a way to view all expressions in a project.. or specifically see a list of all the expressions with warnings?
    Or is it a case of manually going through the hundreds of comps that have expressions dotted around?
    Cheers,
    Dan.
    Todd Kopriva replied 14 years, 7 months ago 3 Members · 3 Replies
  • Todd Kopriva
    February 8, 2012 at 5:19 am
    There is no way to just view all expressions in a project.
    Well, there is one hack:
    Paul Tuersley has recently released a script ( https://aescripts.com/pt_opensesame/ ) that is intended for saving After Effects projects in a form that can be opened by previous versions. This is achieved by saving all project information in a text-based format. You can go through the project file that Paul’s script creates and find just the expressions. They’re easy to find; just search for the word ‘Expression’ in the text file. You can also tell whether the expression is enabled, so that will give you a good idea of which ones have errors (since ones with errors are disabled).
    I just tried this, and it worked.
    There’s a free trial version of the script, so you can try.
    No, I’m pretty sure that this is not the use case that Paul had in mind—but it is just one of many things that you can do when the project is open to you as a text file in this way.
    (Thanks, Paul.)
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Paul Tuersley
    February 8, 2012 at 8:15 am
    Actually I’ve written another script called that is specifically designed to show a list of all expressions in a project: https://aescripts.com/pt_expressedit/
    You can choose to view only expressions with errors/warnings, or have it attempt to turn these expressions back on if you’ve fixed whatever caused them to break in the first place.
    Paul
  • Todd Kopriva
    February 8, 2012 at 3:41 pm
    Even better!
