Way to simulate time-lapse from regular footage?
Posted by Joseph Murray on October 9, 2012 at 7:01 pmIs there a technique or perhaps a plug-in to simulate time-lapse? Something like grab every 30th frame from 30fps video and assemble it together?
Joseph Murray replied 13 years, 10 months ago 6 Members · 6 Replies -
Chris Walsh
October 9, 2012 at 7:54 pmYou can render your footage out sped up to the max and then render it out as many times until you get the desired effect.
Paul Beller
October 10, 2012 at 8:40 amand with each next render you get worse and worse overall quality unless you are rendering to uncompressed which potentially kills your disk space. J.A.B.A
just another brilliant advice… -
Eddie Macarthur
October 10, 2012 at 8:59 amfasst plugins timewarp is good and very cheap.ed
System; intel i72600k 3.4GHZ, 16GB RAM, Win 7 64 bit. Vegas Pro 11 latest build, Neat Video 3.01. EVGA GTX460 SC graphics
Stealth Recording Studio, Glasgow, Scotland UK
http://www.stealthrecordingstudio.com -
Mike Kujbida
October 10, 2012 at 11:32 amIf you have Vegas Pro, use a velocity envelope and the Ctrl+drag technique to speed it up 12X.
Save this file.
Start a new project, import the veg file and repeat the process giving you another 12x which means a total of 144X.
The advantage to this is no rendering until you’re ready.
Make sure to disable resample on the event. -
Joseph Murray
October 11, 2012 at 10:56 amLots of good ideas, thanks guys! Although a plugin to grab every nth frame does sound like kind of a good idea too. Have to work on that…
