Activity Forums Adobe After Effects Way to send footage to Mocha from after effects for ease when using Dynamic Link?
  • Way to send footage to Mocha from after effects for ease when using Dynamic Link?
    Posted by Nick Shaw on August 16, 2011 at 12:34 am
    I often use Dynamic Link between premiere and After Effects. So with that I am sending a segment of a whole clip to after effects rather that just editing the whole clip. My question is can I do this from After Effects to Mocha (just that segment) without having to render out that segment from after effects and then open it in mocha and track it? Because I dont want to import the whole orignal clip and track that
    Roland R. kahlenberg replied 15 years ago 3 Members · 3 Replies
  • Todd Kopriva
    August 16, 2011 at 12:46 am
    No.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Nick Shaw
    August 16, 2011 at 1:03 am
    Well is there at least a workflow that can speed this process up? If I’m working on a 20 minute film with 40 different shots I have to track you’re telling me I have to use dynamic link, export the clip, and put it into mocha every time? Is there no more efficient way?
  • Roland R. kahlenberg
    August 16, 2011 at 4:43 am
    As per Todd’s reply, there is no dynamic link between Mocha and AE. Mocha needs a fully rendered file. What you can do is to import the entire original 20-minute clip into Mocha and use Mocha’s Project In/Out points to define each of the 40 clips that you want to track in Mocha.
    Further, each layer in Mocha can be defined into its own In/Out points relative to a project’s In/Out points. It’s up to you how you would like to track the 40 segments. I would separate them into groups of 5 tracks per project, just so that the Mocha project doesn’t get too heavy.
    You should also take note that importing a 20-minute clip will result in a long Cache time in Mocha. Therefore, I suggest that you store the 20-minute clip on a fast storage device and disable Mocha’s Cache when importing the said clip.
    HTH
    RoRK
    Intensive AE & Mocha Training in Asia.
