Activity Forums Adobe Premiere Pro way to revise project settings or import export?
  • way to revise project settings or import export?
    Posted by Robert Myers on October 18, 2007 at 8:39 pm
    I’m not exactly versed in the ways of APP2, but I’m slowly learning…
    I have a 4:3 720×480 project with many A/V clips and tracks that I would like to convert to 16:9 720p. I’ve tried to export the project as AAF, but many effects I have implemented will not transfer. There has to be a way I can import or export this project into a HD file configuration…
    Any help is greatly appreciated!
    Robert Myers replied 18 years, 11 months ago 3 Members · 4 Replies
  • Aanarav Sareen
    October 18, 2007 at 9:25 pm
    [saucer] “I have a 4:3 720×480 project with many A/V clips and tracks that I would like to convert to 16:9 720p.”
    Why are you looking to upscale the video?
    – Aanarav
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Robert Myers
    October 18, 2007 at 9:35 pm
    I have recently upgraded my projection system in my simulation rides to HD and would like to use a few of my older videos with the new equipment. I tried exporting the original 4:3 as an uncompressed avi and then importing it into a new 16:9 project to output as an mpeg2, but there was noticeable loss of quality.
  • Harm Millaard
    October 19, 2007 at 10:24 am
    That is to be expected. You increase resolution by at least 50% where there is no information to start with, then on the result you are compressing to MPEG and throwing away 90% of the information.
  • Robert Myers
    October 19, 2007 at 1:27 pm
    Well I found a solution – I was able to “select all” of the items in my sequence and copy them (with the project files automatically selected). I then simply created a new project with the HD settings I desired, and pasted the elements into the new sequence. I really didn’t think this would work – but everything imported without a hitch! I then resized every clip of video to fit the new 16:9 ratio and output to mpeg2 with much better quality than the re compressing an avi.
