Activity Forums Adobe After Effects Way to offset scale with 3D position?
  • Way to offset scale with 3D position?
    Posted by David Lackey on March 29, 2012 at 3:05 pm
    In a 3D comp with a camera with a particular focal length, is there a good expression or shortcut for telling After Effects to offset a scale operation by shifting the X, Y, and Z position of the layer so that it’s apparent scale and position stay the same?
    I’m turning a few 2D comps into 3D and would like to retain the composition of the shots.
    Roland R. kahlenberg replied 14 years, 5 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    March 29, 2012 at 3:27 pm
    Use the following Expression for a layer’s scale property –
    cam = thisComp.activeCamera;
    distance = length(sub(position, cam.position));
    scale * distance / cam.zoom;
    BTW, I believe that this example was taken from the Adobe site but its link seems to be broken.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
