Activity Forums Adobe Premiere Pro Way to import block text into Premiere Pro captioning?
  • Way to import block text into Premiere Pro captioning?
    Posted by Dale Holman wallace on March 26, 2018 at 2:12 pm
    Hi there,
    I’ve got a transcript of a film in Microsoft Word that I’m looking to use to create subtitles for the film inside Premiere Pro.
    Is there a way I can import the entirety of the text into the captioning system and then break it up line-by-line once it’s inside? At the moment, I’m having to copy and paste a line in, then press the ‘+’ icon, then copy and paste the next line in, and so on and so on… It’s pretty arduous work!
    It would be great if there was a system whereby I could get all the text into Premiere, then separate lines as I saw fit.
    Dale
    Roger Averdahl replied 8 years, 5 months ago 3 Members · 2 Replies
  • Chris Borjis
    March 27, 2018 at 5:06 pm
    My go to way of doing this for long form projects is to submit the text file and sound and pay to
    have it captioned….way quicker and not very expensive. I also pay the extra for the result review for 100% accurate results.
    This is the company i use: https://www.automaticsync.com
    For commercials, I caption by hand using the method you described.
  • Roger Averdahl
    March 27, 2018 at 5:11 pm
    Some use Adobe InDesign to create subtitles from Word documents. Take a look at this video and see if it suits your needs: https://vimeo.com/80445034
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
