Activity › Forums › Apple Final Cut Pro Legacy › Way to automate audio normalization?
Posted by Tom Valens on May 20, 2008 at 3:10 amI have a lot of clips that I would like to apply a normalization value of -12 to. I can do this for a single clip with Modify/Audio/Apply Normalization Gain, set to -12, and then OK. Is there a way to automate these steps so I don’t have to go through them every time? I tried the Opt V Apply Attributes, but the Audio Filters checkbox doesn’t seem in include normalization. Thanks for any ideas.
Tom Valens
Tamalpais Productions
Forest Knolls, CAMark Maness replied 18 years, 4 months ago 5 Members · 6 Replies -
David Roth weiss
May 20, 2008 at 3:21 amTom,
I think you can select all the clips at once and apply the normalization to them all at once. It is not a filter, so the filters attribute does not apply as you already dicovered.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Nick Meyers
May 20, 2008 at 3:32 amthat’s a yes on “you can do all at once”
and a no on “it’s not a filter”you don’t apply it like a filter,
but when you run the normalise process, (Modify Menu > Audio > Add Normalisation Gain) FCP adds a gain filter to each clip.make it faster by setting a keyboard command for it
problem with FCP’s normalise is that it makes the adjustment for the whole clip, based on the loudest point.
nick
Alexander Kallas
May 20, 2008 at 4:02 amIn FCP5.1 select the audio clips, then
modify>levels>gain adjust>relative or absoluteCheers
Alexander -
Mark Maness
May 20, 2008 at 4:22 pmThe easiest way to do this is… edit your program as you would normally edit. Edit for proper sound mixing, then you can drop your sequence into a new sequence and normalize that one for broadcast. That way everything is normalized like you want.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Nick Meyers
May 20, 2008 at 4:39 pmbut not with normalisation the FCP sees it.
that just sets the loudest peak in your clip to your designated db.
if it’s a nested sequence,
that just be setting one overall level for the whole show,
which is what you’ve got already!in FCP “Normalise” isnt a “Normalise” filter, that analyses the audio and adjusts it dynamically
its just process that adds a simple Gain filter to each clip.you could export your program and drop that into Something that has a normalisation tool the way what most people understand it.
SoundTrack Pro, would probably do the job.nick
Mark Maness
May 20, 2008 at 5:39 pm[Nick Meyers] “you could export your program and drop that into Something that has a normalisation tool the way what most people understand it.
“This would be the best overall option.
Wayne Carey
Schazam Productions
