Way to add specific value every keyframe?
Hi, I’m currently working on a project with an animated Start and End position. Each keyframe, the Start and End position have to be changed by adding 0.5076 to their value.
Is there an expression that will do this automatically instead of having to do it manually?
Example: value for End in keyframe 1 is 0.5076. Keyframe 2 is 1.0152. Keyframe 3 is 1.5228, etc
I use CS6 if that helps at all.
Much appreciated!
-Brian
