Activity › Forums › VEGAS Pro › WAX Transition Problem
  • WAX Transition Problem
    Posted by Antoine Guy on January 29, 2011 at 9:53 pm
    I have been trying to use a WAX transition in Vegas but I have noticed a little problem. As usual, I start by overlapping two clips of video for about 3 seconds. I then add the ‘Home 4 var PAL’ transition from the ‘WAX Transitions 2’ section. Everything appears to work fine. Except I noticed that just BEFORE the transition kicks in, ONE frame of the 2nd video clip shows. The transition then works fine. Has anyone seen this phenomenon before? Or have a solution?
    Antoine Guy replied 15 years, 8 months ago 2 Members · 2 Replies
  • Theo Van laar
    January 30, 2011 at 10:35 am
    Which version of Vegas are you using?
    Theo
  • Antoine Guy
    January 30, 2011 at 12:05 pm
    Vegas Pro 9.0
