Activity Forums Maxon Cinema 4D Wavy striped material
  • Wavy striped material
    Posted by Baard Kolstad on September 28, 2016 at 10:09 pm
    I’m trying to replicate this in Cinema:
    What I have tried so far is creating a pattern tile in illustrator out of wavy lines and using that image in a luminance material. I tried adjusting the different settings of the material aswell, but it doesnt seem to produce the same result as this image.
    This is a screenshot of what I was able to create in Cinema:
    So as you can see the path of the lines are not at all as smooth as the reference. The more detailed of an explanation the better!
    Thanks in advance
    Jim Scott replied 9 years, 11 months ago 2 Members · 3 Replies
  • Jim Scott
    September 28, 2016 at 10:58 pm
    If you are trying to use the illustrator file as an extrusion in C4D check-out the free CV-Artsmart plugin:
    https://www.digitalsandwich.net/portfolio/cv-artsmart-review/
    If you’re just trying to apply that image on a disc as a material you can load the image as a texture in the color channel and adjust the texture tag’s Length U and V, and the Offset U and V to fill in the disc.
    Here’s the project file:
    10631_disc.c4d.zip
    You’ll need to load your png file into that texture channel.
  • Baard Kolstad
    September 29, 2016 at 7:18 am
    Sorry I wasn’t specific enough. What I’m actually trying to do is creating a sphere with a wavy striped material that looks exactly like the reference seen from a certain angle.
    But thanks for the Artsmart plugin, looks like a neat plugin for future projects!
  • Jim Scott
    September 29, 2016 at 6:46 pm
    It would seem that you would need to paint an undulating texture onto a UV map in BodyPaint3D in order to get a sphere that could be rotated and viewed from multiple angles and have this image displayed (if it is even possible). I did some experimenting and found that I could create the image below of a sphere which has a black/white gradient with Interpolation set to None, and the Type set to 2D-Diagonal applied to it. As you alluded to, the image only works from a certain angle, which required that I pivot and rotate the sphere and adjust the Angle of the applied gradient. I have included a link to the project file for you to peruse. I hope this is helpful.
    10634_wavytexture.c4d.zip
