Activity Forums VEGAS Pro WAVs behaving badly?
  • WAVs behaving badly?
    Posted by Robbie Gould on September 20, 2007 at 8:58 pm
    This is such a weird one.
    I’m putting a clip of a six-second WAV sound in my timeline.
    I’m only using the last two and a half seconds of the clip.
    When I play it on the timeline, or in the trimmer, all is well.
    But whenever I render it (I’m rendering to WMA just to send clip on internet to partner to test it), the WAV file screws up — it plays only the first second or so, looped twice!
    When I try to fix it in the timeline, it becomes impossible to fix. In the trimmer, the original WAV is just a looped version of the first second or so.
    However if I play the original WAV in a media player it plays as normal.
    I have deleted and reloaded the WAV into Vegas, and it begins fine. But whenever I do the render to WMA it screws up again, and exactly the same way.
    Ideas?
    Gould
    Mary Waitrovich replied 19 years ago 2 Members · 1 Reply
  • Mary Waitrovich
    September 21, 2007 at 4:34 pm
    If it’s not a corrupted file, then maybe the .wav file has some weird compression codec. I would try re-rendering as another .wav with the default template. Then try converting it to .wma.
    Good luck.
    Mary Waitrovich
    UW-Madison
