Activity › Forums › Maxon Cinema 4D › waving grass
  • waving grass
    Posted by Bender on February 16, 2006 at 1:05 pm
    hi guys!
    i wanna achieve sort of a “waving grass” effect. i’m using a sketch and toon shader (just outlines) so the grass itself is not very complicated. the movement of the grass is my problem. is there a way to set a “wind” or anything similar.
    would really appreciate recommendations or tutorials!
    thanks so much!
    best
    florian
    Doug Bassett replied 20 years, 7 months ago 3 Members · 2 Replies
  • Arndt Von koenigsmarck
    February 17, 2006 at 11:32 am
    It depends on how you generated the gras. The new Hair module and hairdepartment can be influenced by deformers and have build in dynamics.
    If you just used polygon objects for the gras, use the wind deformer with small amplitudes or even PLA. It depends on the size of your gras area what works best.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
  • Doug Bassett
    February 19, 2006 at 5:54 pm
    I agree with Arndt. There are a lot of “Depens on” this or that but I have seen some really good grass with Hair.
    If you don’t have hair, Place on points is an alternative. you can have a control Null affect the tips of the grass blades like they’re blowing.
    Doug
