Activity Forums Adobe After Effects waveworld loop
  • waveworld loop
    Posted by Ben Peterson on November 19, 2018 at 10:40 am
    Hi, Im trying to figure out how to make a seamless loop with waveworld. I just want a ripple from the centre using the height map that will continue to loop seamlessly. Can someone please explain how I can do this please. Im not sure which parameter I need to key frame.
    Richard Garabedain replied 7 years, 10 months ago 3 Members · 6 Replies
  • Kalleheikki Kannisto
    November 19, 2018 at 10:46 am
    I suspect you need to run waveworld for long enough so that you get to the point where the first waves fully fade out, then manually locate two frames that you can loop between. It would be the time frame within which a wave moves one wavelength’s worth (minus one frame).
    Senior Graphic Designer
  • Richard Garabedain
    November 19, 2018 at 4:45 pm
    you do it with a gradient…ive done this before…a while ago
  • Ben Peterson
    November 19, 2018 at 8:14 pm
    So do you remember the method used with the gradient?
  • Ben Peterson
    November 19, 2018 at 8:16 pm
    Is it possible to alter the time in which the wave fades out?
    November 19, 2018 at 10:27 pm
    i guess it wasnt wave world…i must be confused with something else
    November 19, 2018 at 10:36 pm
    it was the displacement map…which is pretty similar actually
