Activity › Forums › VEGAS Pro › Waveform videoscope question
  • Waveform videoscope question
    Posted by Mike Costantini on July 23, 2006 at 8:16 pm
    To this day I still don’t understand which boxes to check in order to get proper readings on the waveform videoscope – 7.5 IRE Setup or Studio RGB or Both or None?! Everything changes when you check the boxes. Is there a sure fire way to know what I should be doing so that all my blacks and whites and everything is NTSC legal? I notice when you check the 7.5 IRE box it moves “0” up to 7.5% At least I think that is what that solid horizontal white line represents? As you can see I’m confused overall 🙁
    Stephen Mann replied 20 years, 2 months ago 2 Members · 3 Replies
  • Stephen Mann
    July 25, 2006 at 8:06 am
    Basically, unless you are going to broadcast via analog tape, you can forget about the 7.5 setup.
    Adam Wilt (adamwilt dot etc) has a nice writeup explaining 7.5 setup.
    Stephen Mann,
    MannMade Digital Video,
    San Jose, CA
  • Mike Costantini
    July 25, 2006 at 8:22 am
    Ok cool, so leave the 7.5 checkbox unchecked, what about the other, about the RGB color thing?
  • Stephen Mann
    July 27, 2006 at 7:06 am
    I always use Studio RGB, but nothing I’ve shot has gone directly to air.
    Steve M.
    Stephen Mann,
    San Jose, CA
