Activity Forums Apple Final Cut Pro Legacy Waveform shows intermittently
  • Waveform shows intermittently
    Posted by Andy Hutchinson on May 26, 2005 at 8:55 pm
    I am trying to edit some audio using the waveform on the timeline. It appears for a while and then there are just small “X” for about 4-5 seconds and then the waveform shows up and then it disappears for about 5 minutes. The volume of the audio on either track is still there.
    It shows the “X” normally when it is refreshing the waveform but all day….and nothing.
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
    OS-10.3.7, FCP4.5, SP 2.05, Dual 2.5 G5, 2 gigs RAM; Sys HD 200G : WD 200G 7200rpm with 8 Meg buffer; 2 WD 250G 7200 rpm with 8 Meg buffer FW enclosure; Lacie FW800 card; Maxtor 120G FW for storage, 1 WD,
    Fred Miller replied 21 years, 3 months ago 2 Members · 2 Replies
  • Andy Hutchinson
    May 27, 2005 at 4:27 pm
    Also the same audio clip looks fine on my PowerBook G4. The problem is on the G5.
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
  • Fred Miller
    May 29, 2005 at 4:41 am
    I would try trashing the waveform cache files. I’ve never done it, but I assume that doing this would force FCP to rebuild the waveforms on your clips.
    G5 2Gg Dual
    1.5Gg RAM
    Panther
    ATTO UL3D
