Activity › Forums › Apple Final Cut Pro Legacy › Waveform FCP losing asking to re-render, even footage that has no effect (!)
  • Waveform FCP losing asking to re-render, even footage that has no effect (!)
    Posted by Alan Langdon on September 22, 2014 at 7:31 pm
    MacBookPro 2.0Ghz i7 8Gb RAM intel Iris Pro (retina) – external Lacie Thunderbolt drive – OS 10.9.5
    So I have a ProRes HQ 1080p sequence, with 95% ProRes HQ footage in it. The project is about 67 min long. I render the whole timeline, export, all is fine. Then when I reopen the project hours later on the same setup, I decide to change color correction on one clip in the sequence. I use the built-in waveform monitor. With this, about 30 % of my sequence goes “un-rendered”, even clips that are ProRes HQ (the same as the sequence settings) and that have NO effects or motion changes…! To be specific, they have orange bars, since I set the sequence to real-time effect playback). When I turn off Waveform, the sequence goes back to being “rendered”.
    So what is the waveform doing that it temporarily makes several clips ” unrendered”?
    Nick Meyers replied 12 years ago 2 Members · 1 Reply
  • Nick Meyers
    September 22, 2014 at 11:58 pm
    it is “rendering” what you see in the waveform.
    there’s a setting somewhere that will turn that off, but the waveform wont “play” along with the sequence.
    nick
