Activity Forums Adobe Premiere Pro Waveform Error (Solid Red in Sequence, no Audio)
  • Waveform Error (Solid Red in Sequence, no Audio)
    Posted by Brandon Adams on November 16, 2012 at 3:39 pm
    I keep getting a strange error. Particular clips in a sequence are having problems with the audio. It will not play any audio and the waveform is just a solid red box (see photo). Double clicking the clip brings up a solid red “waveform” in the source monitor, but opening the same clip from the project panel shows the waveform correctly and plays the audio just fine.
    Any ideas how to fix the problem? I’ve already gone back to the original source and replaced the clip in the sequence, only to have it revert back to the same problem the next time I opened Premiere.
    (These sequences originated from a different PP project that I copied and then pasted into this project. It seems others have reported the same problem when copying sequences like that https://forums.adobe.com/message/4748784#4748784 )
    -Brandon
    Sheldon Norton replied 11 years, 9 months ago 12 Members · 13 Replies
  • 13 Replies
  • John-michael Seng-wheeler
    November 16, 2012 at 11:39 pm
    [Brandon Adams] “(These sequences originated from a different PP project that I copied and then pasted into this project. It seems others have reported the same problem when copying sequences like that”
    Looking around the internet has turned up many examples of this, and everyone seems to agree it’s a bug related to copy and pasting audio from one project to another.
    Instead, try importing the original PP project into the current one, open the timeline where these files originally were, and then copy them to the new timeline (which is now a copy/paste inside the same project. See if that works.
  • Brandon Adams
    November 16, 2012 at 11:42 pm
    Thanks John-Michael, I’ll give it a shot
    -Brandon
  • Rob Carr
    November 18, 2012 at 2:36 am
    I may have found a way to fix your problem.
    I have had this similar problem…because of some Premiere version mix up (i still do not quite understand it, and it only is an issue with this file) any time i want to edit this one particular project, i have to start a new project, and import the old sequence into the new project. Very frustrating. It would always work fine, but recently the audio waveform would appear red, and i wouldn’t be able to reconnect it to edit.
    Anyways, just now I reconnected that audio by taking out the existing “Mark In” and “Mark out” paramaters that were set before. One i did this, the sound information came back.
    I hope this helps. I almost had a heart attack there.
  • Brandon Adams
    November 19, 2012 at 3:55 pm
    Thanks Rob. Did you remove the mark in and mark out for the sequence or for the individual clips?
    -Brandon
  • Ricardo Birnbaum
    May 11, 2013 at 7:24 pm
    Thanks, importing the Premiere Project via, File, Import, (premiere project where the clips were originally placed) worked for me.
  • Rob Bellon
    May 27, 2013 at 5:34 pm
    I had the same problem. Found the fix in the Adobe forums: https://forums.adobe.com/message/4778837#4778837
    Copied here:
    I’ve found a solution for this, at least in my case. For some reason Premiere sometimes fails to assign the audio channels.
    In a sequence with red “disconnected” audio, try this:
    1) Select all of the affected audio
    2) Right click and select “Audio Channels”
    3) Make sure the “Source Channel” drop-downs are all assigned to either a right or left channel.
    For some reason, these were all assigned to “none” each time this happened to me.
  • Glenn Allyn
    July 6, 2013 at 5:29 pm
    Thanks, Rob Bellon! That solution totally worked!
  • David Atkins
    August 18, 2013 at 1:08 pm
    Thanks Rob! That totally fixed my issue. I’ve been editing a project in CS6, and I had an assistant editor logging and syncing in cs5.5. Everything imported to cs6 correctly, but I was baffled by the red audio. I appreciate the help!
  • Riaan Coetzee
    September 18, 2013 at 11:30 am
    Thanks Rob this worked great for me as well.
  • Tracie Bosket
    January 7, 2014 at 8:19 pm
    Rob! Excellent! I have had this problem (PP 6) may times before and always had to go back and start again from an earlier version. Your solution works great.
    Thank you, thank you!
