Activity › Forums › Adobe Premiere Pro › Waveform doesnt show IRE units
Posted by Michal Bronec on November 8, 2011 at 12:52 amWhen I open Waveform scope in Premiere CS4 I see it in “v” units (dont know what it is – volts?), I dont see it in IRE units. Whats wrong?
Ann Bens replied 14 years, 10 months ago 4 Members · 8 Replies -
Todd Kopriva
November 8, 2011 at 4:23 amAre you using the English version? Or, say, the French version?
IRE units are used for NTSC video, whereas volts are used for PAL. I believe that the French and German versions default to showing volts for PAL. (I’m typing this on my phone right now, so I can’t confirm this for certain.)
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Ann Bens
November 8, 2011 at 11:15 amThe scopes correspond with the sequence (in the English version at least)
If its pal (25 frames) the scope is automatic set to volts.
This is for CS5.5. I cannot confirm this for CS4.———————————————–
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Todd Kopriva
November 8, 2011 at 3:39 pmThanks for the clarification, Ann.
I just checked in Premiere Pro CS4, and switching from an NTSC sequence to a PAL sequence does change the Waveform Monitor units from IRE to volts.
Michal Bronec
November 8, 2011 at 4:40 pmYes, the sequence is in PAL. I didnt know that volts are used for PAL.
I know that with IRE units I shouldnt cross 100 IRE line and I should go below 0 IRE line. What about volts? I dont know how to read it. Does anybody know? -
Jeff Brown
November 8, 2011 at 5:00 pmTektronix have produced some very good “learning” materials; they might help. Not sure if the SD literature is still available.
-Jeff
Ann Bens
November 8, 2011 at 8:29 pmStay between 0.3 and 1.0.
https://library.creativecow.net/devis_andrew/YC-Waveform-graph-Premiere-Pro/1———————————————–
Michal Bronec
November 8, 2011 at 11:40 pmThe guy from the video works in PAL and has it in IRE units 🙂
Ann Bens
November 9, 2011 at 7:14 pmAndrew is in Pal-land but the footage from Adobe is ntsc.
