Activity › Forums › Apple Final Cut Pro Legacy › waveform do not match the actual audio sound
Mohan Patil replied 14 years, 4 months ago 12 Members · 25 Replies
Andrei Bocharnikov
June 23, 2010 at 8:38 amHi Ty,
yes I was able to fix the problem following the trick posted to this thread by Rike Rodegro (on Dec 17, 2009 at 5:39:42 pm) and in the next post by me you can see what exactly I did in my case to solve the problem.
MacPro Dual Quad 2.8 GHz, 4 GB DDR2 SDRAM, Leopard 10.5.8, QT 7.6.6, FCS3
Ty Ford
June 23, 2010 at 11:41 amAndrei,
OK, but my project is not HD, 50fps or 720p50. After doing the below, can I reset to my miniDV settings?
Regards,
Ty Ford
[Andrei Bocharnikov] “Rike,
– removed file from the timeline and browser.
– in easy setup i selected HD as FORMAT, 50 fps as RATE and DVCPRO HD 720p50 as USE
– pressed SETUP, then saved the project and QUIT FCP.
– opened FCP again, opened the project file and reimported audio with drag and drop from the finder to FCP browser.
– dropped the audio to timeline… and it WORKS!!!
thank you very much… you saved my neck.
for me from the first look the instructions were irrelevant to the problem because i have audio without video associated and PAL or NTSC or framerate do not so important. But i just surrendered to the instructions and adjusted it to my project settings and it helped … believe me or not 🙂
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitar -
Andrei Bocharnikov
June 23, 2010 at 1:24 pmTy,
yes. you just have to setup it according the settings of your project. I think would be better if you follow the instructions in Rike’s post. He has also one link to the original article at apple’s site.
let us know if it works for you too,
AndreiMacPro Dual Quad 2.8 GHz, 4 GB DDR2 SDRAM, Leopard 10.5.8, QT 7.6.6, FCS3
Devon Leesley
September 5, 2010 at 4:09 amMy problem is this. All is in alignment on the timeline. When I burn to a dual layer dvd, it goes out of alignment by a hair or two 3 quarters of the way in. THe movie is almost 2 hours long. Help. Thanks
Mohan Patil
April 23, 2012 at 12:12 pmHi, I have same audio sync problame
my project properties are
sequence seatings : 1920*1080 apple proress LT, 23.98 fps, square pix, 16:9for audio dubbing they demanded video at 24 Frame Rate so i rendered this video at 24fps and i given them. Now the final dubbing audio which they have given is accourding to this 24fps video but my timeline
is 23.98 so audio is not syncking. what should i do now.and audio is also not exactly as waveforms its missmatche
please helpBlacklinus,India
