Activity Forums DaVinci Resolve Wave bug on pressing reset buttons ?
  • Wave bug on pressing reset buttons ?
    Posted by Sascha Haber on January 6, 2011 at 7:36 am
    Hi guys, I am in the middle of a short movie and updated to 7.1
    I noticed a strange behavior on my Wave.
    When pressing the ball reset button, I reset the three color values as expected.
    But when pressing the ring reset button, it resets both !?
    Is that a feature I don’t understand or a bug ?
    I normally wish to tweak those independently and not reste my color adjustments when resetting the master.
    The goes for all three by the way.
    A slice of color…
    DaVinci 7.0.3 OSX 10.6.5
    Dual Xeon 2,4 RAM 6 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    Michael Cinquin replied 15 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Cinquin
    January 6, 2011 at 3:01 pm
    try the setting “Master reset maintains RGB balance”
    Michael Cinquin
    Final Cut Pro – Avid Media Composer editor
    DaVinci – Color – Baselight colorist
    http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode – Keycode calculator
  • Sascha Haber
    January 6, 2011 at 5:42 pm
    Thanks for the hint, yeah its checked now
    …and it does the same thing…
    How does it work for someone else ?
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Jay Lee
    January 6, 2011 at 9:31 pm
    You can check out Alexis’s explanation here:
    https://vanhurkman.com/wordpress/?p=443
    Cheers,
    J
  • Sascha Haber
    January 7, 2011 at 7:29 am
    Good Morning,
    Tanks for pointing me to this friendly article .
    Now back to the question.
    Why does the luma or master reset also resets my RGB balance ?
    It doesn’t make any sense to me and I lost quite a few gradings yesterday using it accidentally .
    On our Scratch or in Color it’s pretty clear to use and I really like to keep both of separate .
    Also it works as expected when double clicking the Y value only in the interface afaik.
    Ring reset should only reset the dial , button reset the balance.
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Vladimir Kucherov
    January 7, 2011 at 3:57 pm
    I think the functionality you’re looking for can be enabled by clicking
    “Master reset maintains RGB Balance” in the project Settings tab. From the manual:
    This control defines how the panel reset buttons reset the
    primary color correction. Normally, a reset will return the
    primary correction values to their default values. When this
    option is selected, reset will function as follows:
    1) Clicking the master reset key will reset the YRGB values so
    that the overall values are kept and the ratio of YRGB to each
    other is maintained.
    2) Clicking the RGB reset button will find the average value
    of RGB, and set the RGB to that value.
  • Sascha Haber
    January 7, 2011 at 4:07 pm
    Well, then either my Wave is faulty or something else is not working.
    Here it comes again…
    I press the lower small dot reset button and RGB resets, thats fine.
    I press the upper ring reset button and I hope this would ONLY reset the overall setting, and keep the RGB balance the way it was, but it doesnt.
    I would understand if it resets the dial to zero and respect the positive and negative values of the RGB balance.
    But its nulls everything.
    With or without that setting.
    Can anyone with a Wave please chime in and try that ?
    A slice of color…
    DaVinci 7.1 OSX 10.6.6
    Dual Xeon 2,4 RAM 24 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Michael Cinquin
    January 7, 2011 at 7:58 pm
    yes I did the test with my wave, and it behaves like you described.
    It looks like “Master reset maintains RGB balance” does not work as it should, at least in 7.1
    Michael Cinquin
