.wav export settings question
Hi all, and thanks in advance.
I have a client who needs a .wav audio file as final delivery for a project we are working on. I exported a .wav from Premiere Pro CC on a Mac with the default “WAV 48 kHz 16-bit” preset and the client came back and said that their system did not accept it.
The client gave me the below specifications:
.wav with 16-bit_wide-band/pcm_format
I’ll admit I don’t know audio that well (hence the reason I am using Premiere to edit it) so I’m not sure what the problem is. Based on my quick reading of narrow- vs wide-band and PCM audio, the file Premiere is spitting out should be meeting these specs. Is this an issue on my end or their end?
Thank you!
