WAV bye bye
Posted by Kelly Griffin on February 20, 2013 at 11:20 pmI’ve been strolling along just fine with SVP10; everything seems peachy, very few crashes. However, there’s been one PITA thing I’ve been dealing with since install: WAV files just don’t play; they’re always corrupted.
It was suggested to test the trial version of SVP12, which I’ve just done. Same schtick. Considering that Vegas seems to like just about ANY other filetype I’ve come across, it’s a huge bummer that it (mine) won’t play one of the most vanilla flavors on the planet.
ANY ideas about what might be going on would be swell to hear.
Thank you,
–Kelly
Stephen Mann replied 13 years, 7 months ago 3 Members · 7 Replies -
Steve Rhoden
February 21, 2013 at 1:37 amSince vegas 10 and 12 has the same issue with the format,
its probably something with your system itself, a conflict
with another software or something, hard to say which.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-832-4956 -
Stephen Mann
February 21, 2013 at 4:07 amI use wav files frequently.
Try running one through MediaInfo to make sure it’s a compatible wav file.Here’s one of mine that I just used in a project:
General
Complete name : D:\Documents\Projects\SFX\Ducks.wav
Format : Wave
File size : 51.6 MiB
Duration : 1mn 34s
Overall bit rate mode : Constant
Overall bit rate : 4 608 KbpsAudio
Format : PCM
Format settings, Endianness : Little
Codec ID : 1
Duration : 1mn 34s
Bit rate mode : Constant
Bit rate : 4 608 Kbps
Channel(s) : 2 channels
Sampling rate : 96.0 KHz
Bit depth : 24 bits
Stream size : 51.6 MiB (100%)
———————You haven’t installed a codec pack, have you?
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Kelly Griffin
February 21, 2013 at 4:25 amHey Steven,
No, no codecs installed. I’ll try what you said, but this is just so bizarre (and frustrating).
–Kelly
Stephen Mann
February 21, 2013 at 6:00 amYou could also post a small wav file that you’re having trouble with and let us try bringing it to the Vegas timeline.
Steve Mann
Kelly Griffin
February 21, 2013 at 6:32 pmStephen–
I just responded and uploaded a culprit WAV file and a corresponding “good” AIF of the same thing. I don’t see my post anywhere, so please let me know if you don’t get them and maybe I could e-mail them directly to you (?)
They’re about 4MB.
Thanks for your help!
–Kelly
Stephen Mann
February 21, 2013 at 8:16 pmWhen you upload a file to the forum, you get a link that you copy and paste into your message on the forum. Alternately you can use Dropbox.
Steve Mann
Stephen Mann
February 22, 2013 at 10:56 pmI got your WAV file from the Zoom and it plays fine in both Version 11 and 12 here.
I am still inclined to think this is a codec problem. Here’s an article from Adobe that does offer a good general codec troubleshooting guide.
You can see what codecs are installed on Windows by typing MSINFO from start/Run, drill down to Components/Multimedia/Audio codecs. Curiously, there is no wav codec listed on my system
Hope this helps.
Steve Mann
http://www.mmdv.com
