Activity Forums A.I. Watermark Removal (News logo, master damaged/unuseable)
  • Watermark Removal (News logo, master damaged/unuseable)
    Posted by Bill Hilferty on April 14, 2026 at 2:13 pm
    Hello! I’ve tried searching for this but couldn’t find anything similar.
    I have a piece of archival news footage that has a watermark right in the middle of the frame over a face. The original master is damaged and can’t be used, so was wondering what options, if any, I would have to remove the logo. I was thinking today with AI it might be doable? If not, is it just a paint job? The clip is 5 seconds long. Thank you for any advice!
    Bill Hilferty replied 4 months ago 3 Members · 5 Replies
  • John Fishback
    April 14, 2026 at 3:40 pm
    I spent a minute trying to do this to your still with TopazLabs Photo AI. It’s not perfect. Just trying to see if AI could do it. I’m not familiar with an AI app that would remove this from moving footage. You could export the video as a PNG sequence, then fix each frame, and then turn them back into video. Might be faster than painting.
  • Bill Hilferty
    April 14, 2026 at 6:03 pm
    thanks so much! I ended up using Runway ML’s remove object tool and told it to remove the watermark. it worked good enough for our purposes!
  • John Fishback
    April 14, 2026 at 6:38 pm
    Glad you found a solution.
    April 16, 2026 at 12:19 pm
    Hey Bill and John,
    John: Topaz Photo AI was an inspired choice, I would not have thought of that.
    Just for “fun” it might be interesting to batch-process a PNG sequence?
    Topaz has got info here:
    https://docs.topazlabs.com/topaz-photo/functions/batch-processing
    Bill, when I saw your post, my initial thought was from growing up in a time where you could not scan bank-notes on most flatbed scanners. That there might be a time where where watermarked videos might run the same risk.
    Then, watermarking for copyright, these days are embedded in the picture as an invisible feature.
  • Bill Hilferty
    April 16, 2026 at 6:30 pm
    For another clip with a different watermark which was arguably even tougher since people’s legs were moving behind it,I exported a JPG sequence and tried removing it in Photoshop using Generative Fill. I even set up an action to process every frame. Each frame looked great on its own, but playback was completely unusable. I ended up switching to Runway for that one as well. Might be fun to try Topaz next and see how it compares.
