Activity Forums Adobe Photoshop Watermark
  • Watermark
    Posted by Orthanc on December 15, 2005 at 4:38 pm
    I just created a watermark action as described in this tutorial, in order to batch process my images:
    https://av.adobe.com/russellbrown/CS2WatermarkActionSM.mov
    Unfortunately there are two problems:
    1.) For some images the watermark is much too big, for some too small. How can I create one whose size is always the same, relative to the size of the image?
    2.) The watermark is not always created as the top layer, thus altering the result. How can I make sure that the watermark is always at the top, regardless of which layer is selected in the saved document?
    Orthanc replied 20 years, 9 months ago 2 Members · 2 Replies
  • Mike Gondek
    December 16, 2005 at 8:40 pm
    1) Photoshop does not have a scale command where you can enter the percentage of a page. The best help I can offer is view >> new guide >> and input 90% horizontal (do 1 more hor adn 2 more vertical to get a box). You would then have to manually scale to get the layer to fit inside the box.
    2)Record Shift Ctrl J or the bring to front command into your action.
  • Orthanc
    December 16, 2005 at 9:03 pm
