Activity › Forums › Boris FX Particle Illusion › water wake
water wake
Posted by Byronregpi on October 19, 2005 at 12:51 pmhello again sorry HI everyone how can i add for Attachments post for picture how?? can i add for that ?? just show something
Byronregpi replied 20 years, 8 months ago 3 Members · 13 Replies -
Alan Lorence
October 19, 2005 at 1:15 pmYou can’t add attachments to a post, but you can include references to files on a server. So if you can upload your files somewhere, you can include a link to them in the post.
You can also embed an image into a post, but again it’s just a reference to an image file on a server somewhere else. For instance, if you have found an image of an explosion that you want to show people, you can embed it here:
To do this, copy the image address, then click the little camera icon above (between the “U” and “L” icons), then paste the image address in.
Alan.
wondertouch -
Byronregpi
October 19, 2005 at 4:39 pmanyway i try that use i give up i use just website ok you can look that what look like i want make special effects i want know what kind of that for final cut pro or visual effects or what i need want know because i want use that for film effects
like front and side either wantknow how use that make effect do have any
you can look that websitehttps://www.photographyblog.com/gallery/data/3120/1233WATER_WAKE_OF_BOAT_BXW1.jpg
https://www.nps.gov/yell/slidefile/water/lakesponds/yellowstonelake/Images/06424.jpg
Elvis Deane
October 20, 2005 at 7:43 pmHere’s a REALLY quick test that I made of that sort of effect. This does use a pI3 only feature (where you can specify each particle type’s emission angle and range), but you could still recreate it in pISE using 3 emitters instead of one.
https://pi.shockingtales.com/videos/boatWake01.aviI have to run to a class now, but I can try to write some instructions when I return.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures -
Byronregpi
October 21, 2005 at 12:36 pmok that https://pi.shockingtales.com/videos/boatWake01.avi not work did wait loading might longer i am understand i can wait for you ok anyway
Elvis Deane
October 24, 2005 at 9:11 amYou need DIVX 5 installed to be able to view that clip.
Elvis Deane!
Byronregpi
October 24, 2005 at 12:21 pmi finish install download finish then what next ??? what i need do with that before i send https://pi.shockingtales.com/videos/boatWake01.avi that what me need do with that ?? because i try put where how please explain thank you
Byronregpi
October 24, 2005 at 5:49 pmHi want know any Emitter library load different effect have Words etc i want know how can make background behind person for example bomb or fire or any for example when stand behind fire on house how can person stand front and behind house fire cover or water whatever how but i have only particleIllusion SE i dont have 3.0 not yet
Elvis Deane
October 24, 2005 at 9:17 pmIf you have a compositing program like After Effects or Combustion, you can create masks in that, and then render out your effects in pI and place them behind the layer with your actor on it.
Wax from Debugmode ( https://www.debugmode.com/wax/ ) is a free compositing program that lets you draw masks around people and animate them if you don’t have any other compositor. I haven’t used it in a few versions, so I don’t know how good the masking is (the feature you’re looking for is called RotoMate), but it might do the job for you.
Elvis Deane!
Byronregpi
October 24, 2005 at 11:56 pmi was download that wax it very cool but one thing problemi have only WXP not have AVI or MPEG ETChow add with wax ( https://www.debugmode.com/wax/
Elvis Deane
October 25, 2005 at 2:30 amIf you go to Project>Add Media File, then you can bring in AVIs or other videos.
Elvis Deane!
