Activity Forums Maxon Cinema 4D Water Texture
  • Water Texture
    Posted by Lars Wikstrom on December 15, 2006 at 9:54 pm
    I created a globe that kind that shows the world that people have in homes. I wanted to replace the water texture with a texture that ripples like it is real water.
    I have Version 10 but I don;t know where to start.
    -Lars
    Mylenium replied 19 years, 9 months ago 2 Members · 3 Replies
  • Mylenium
    December 16, 2006 at 9:21 am
    Create a layered shader in the bump channel. Use any type of Noise you deem suitable and on the second layer use an image texture with your continents as a layer mask.
    Mylenium
    [Pour Myl
  • Lars Wikstrom
    December 16, 2006 at 6:55 pm
    When you say layer do you mean create a second object under the first object? Or is it something that happens in the texture itself?
    -Lars
  • Mylenium
    December 16, 2006 at 7:11 pm
    In the material manager. Select a “Layer” shader and then put the other shaders inside it.
    Mylenium
    [Pour Myl
