Activity Forums Boris FX Particle Illusion Water Ripples Interacting
  • Water Ripples Interacting
    Posted by Matt Grunau on August 12, 2008 at 2:27 am
    Is it possible to have water ripples react to one another when they collide? I am trying to do a Matrix/Independance Day type shield effect, and the results look good with regular ripples as a displacement and compound blurs, but if they reacted with each other the effect would be much more convincing.
    Any ideas?
    Matt
    Matt Grunau replied 18 years ago 2 Members · 2 Replies
  • Alan Lorence
    August 12, 2008 at 8:21 pm
    Not in particleIllusion — there are no interparticle collisions.
    If you’re generating essentially cocentric rings which you then use as your displacement map, if you keep the range of colors (greyscale) at 50% max, then when you combine ripples, you’ll get the interference patterns you want.
    So instead of rendering ripples that go full white on black, make them go to 50% (grey) instead, so when you add 2 of these ripple images on top of each other, you’ll get some areas that add up to full white.
    Does that make sense?
    Alan.
    http://www.wondertouch.com
  • Matt Grunau
    August 12, 2008 at 9:37 pm
    That makes perfect sense, on small hitch would be that when you create a displacement map or compound blurs (I’m using AE) the background color needs to be 128,128,128. I could do alphas, but I can never get the nice defined edges that I see in PI.
    Actually, I know exactly what I will do, I’ll make them exactly as you suggested, but against a black background, and then in AE, simply use Knoll Unmult, the best free plugin ever made. Then it’s a simple precomp and it’s done.
    Thanks Alan.
