Activity Forums Zaxwerks water ripple type in 3d invig pro?
  • Matt Rhodes
    April 20, 2005 at 5:59 pm
    Hi Jay.
    There is no “water ripple” material type in the Invigorator, but you may create a
    ripple texture and apply it to your objects. By creatively using diffuse maps, bump
    maps, and specular maps, you can create some convincing results.
    Good luck.
    Matt Rhodes
    Zaxwerks, Inc.
  • Jon Okerstrom
    April 22, 2005 at 5:37 am
    Hi Jay,
    Matt offered some good ideas about creating water-type materials.
    If you’re looking to create a ripple effect in the actual 3d objects, use layer cycling. You can distort your objects over a series of Illustrator layers. If you need help with that, let us know.
    Jon
