Activity Forums Maxon Cinema 4D water particles
  • water particles
    Posted by Jaymez Jansen on September 29, 2015 at 6:27 am
    Hello,
    I’m using an emitter / metaballs / sphere to create water and it’s looking pretty good. What I need it to do however is flow down a wall, hit a floor and flow to a specific spot on the floor. The emiter should be able to be placed on any point on the wall and flow to the same space. I’ve used gravity to get it to the floor, but it doesn’t want it sort of fall and sits and half of it flows through the floor.
    the closest I got was with a deflector, but I couldn’t get it to flow to the specific point, just off the edge.
    Any tips?
    cheers,
    jaymez
    Jaymez Jansen replied 10 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 29, 2015 at 2:32 pm
    Try using a particle attractor object. I’d use it in Force mode with a very low strength value (around 0.1).
  • Jaymez Jansen
    September 29, 2015 at 6:06 pm
    I’ll give it a try. thanks!
