Activity › Forums › Adobe After Effects › Water Fountain
  • Water Fountain
    Posted by Neil Harris on June 8, 2006 at 10:41 am
    Hi, I have searched the archives and the trapcode site and found nothing completly relevant.
    I am trying to make a water fountain within After effects using trapcode particular.
    The results are ok but I was hoping one of you clever cows might have some tips/tricks for making a
    water fountain(quite a large one) look better.
    Working on in afx7 with particular 1.0.1.
    Any help greatfully recieved.
    Fabiano Peres replied 20 years, 3 months ago 3 Members · 3 Replies
  • Justin Productions
    June 8, 2006 at 2:26 pm
    Well…If I were you I’d put my Emitter point on the bottom of my comp window and turn up the gravity. Then…er…depending on how realistic you want your fountain to be, I’d used it as a displacement map. But, maybe not the best idea. Maybe you’d want to put the Motion Blur up, and the particle feather too.
    Hope that helped.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
    June 8, 2006 at 2:35 pm
    *Gravity down, sorry.
    There’s a Trapcode forum in case you didn’t knew.
    Justin Productions
  • Fabiano Peres
    June 8, 2006 at 3:19 pm
    Hi, if you already have Particular, you should upgrade for Particular 1.5, it’s totally free and may help you…
