Activity Forums Adobe After Effects Water Droplet on Apple?
  • Water Droplet on Apple?
    Posted by Mike Wheeler on February 5, 2007 at 3:11 pm
    Hey..
    I am trying to create a water drop running down the side of an apple… the drop needs to pick up other drops as it runs over them…. I can make the drops look realistic using photoshop but when I bring it into AE it looks garbage….
    Does anyone have any tips on how I can achieve this effect? Are there any water plugins that would do this?
    Mike Clasby replied 19 years, 7 months ago 4 Members · 3 Replies
  • Iancorey
    February 5, 2007 at 6:11 pm
    Sounds like a good start, but what type of apple to use? 😉
  • Lanach
    February 6, 2007 at 11:31 am
    You may also try LensProIII plugin for After Effects. There is effect of realistic animated droplets and other crystals.
    Look at samples here https://www.alphaplugins.com/products/products.php?menu=get_prod_id&p_menustate=&prod_id=16&prod_page=lenses
    These droplets can be animated with a lot of ways.
    http://www.alphaplugins.com
  • Mike Clasby
    February 6, 2007 at 8:06 pm
    Hey Macrohead,
    This was for a teardrop, but good for water droplet.
    CC Blobbylize (referencing a white teardrops on Black Background), with Radial Shadow.
    You need three layers.
    Dup the Apple image layer.
    Above the two Image layers:
    Make a new white Solid, create a mask on that solid the shape of your water drop.
    Now animate the Mask Shape to get the flow of the teardrop.
    You can double click the mask points to change the Mask Shape over time (it’s like Transform in Photoshop),
    as it grows and flows, and/or animate points on the mask individually. Feather the mask to about 5 or so.
    Precompose this layer, Layer>Precompose, move all attributes.
    This precomped layer is above the two Image layers, turn off its eyeball.
    Here’s the waterdrop:
    In the Image layer, second down:
    Effect>Distort>Blobbylize:
    Blob Layer: Layer 1 (your Animated Tear Shape)
    Property: Alpha
    Softness: Lower a bit, maybe 10
    Light>Light Intensity: Up to 300 or to taste
    Light Height and Direction:To taste to fit your Scene Lighting.
    And for a little more depth, Effect>Perspective>Drop Shadow (tweak to taste)
