Activity › Forums › Maxon Cinema 4D › Water Drop & Splash: How was it done?
Posted by Julia K on August 23, 2013 at 2:26 pmI’m trying to recreate this effect. CINEMA 4D – WATER DROP & SPLASH – TEST from PRJECT-4D on Vimeo.
Anyone know how this was done? Any help is greatly appreciated!
Adam Trachtenberg replied 13 years ago 2 Members · 3 Replies -
Adam Trachtenberg
August 23, 2013 at 3:31 pmThe artist says that he used TP, so there’s a clue. My guess is that he used the Effects>Ripple shader to create the ripples, and he used TP to spawn the splash particles when the drops collided with the water plane. Then he probably used metaballs on the spawned particles, with a gravity node, to make the splash.
Julia K
August 23, 2013 at 4:45 pmThank you Adam!
I was mostly curious about the ripples, they didn’t seem like a ripple shader. Especially the random peaks and the uneven quality…. but maybe there is a setting I’m missing in the ripple shader…
Adam Trachtenberg
August 23, 2013 at 7:28 pmIt certainly could be something else, but it might also be the ripple shader layered with some noise shaders. I did a quickie attempt to reverse engineer here: https://www.youtube.com/watch?v=e1F9FJJUwsc&feature=youtu.be
I layered a turbulence shader over the ripple shader (overlay mode) with an edited version of the same ripple shader as a mask in between.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
