Activity › Forums › Apple Final Cut Pro › Watch it… 10.7.4 update…
Posted by David Battistella on May 22, 2012 at 12:15 pmSince installing the 10.7.4 update, I am having problems opening up the project library.
One big beach ball.
Come on.
This is getting exhausting.
David
______________________________
The shortest answer is doing.
Lord Herbert
https://www.davidbattistella.comJeremy Garchow replied 14 years, 4 months ago 3 Members · 11 Replies -
David Battistella
May 22, 2012 at 12:27 pmEarly test is showing that after the update FCP X did not like a SUB FOLDER inside the PROJECTS folder.
With the projects REMOVED from the SUBFOLDER, the beach ball hang does not repeat itself.
David
Lord Herbert
https://www.davidbattistella.com -
Michael Garber
May 22, 2012 at 4:17 pmInteresting. Glad you figured it out. I recently cut a project with subfolders and did not have that same issue. How many subfolders did you have? Mine went two levels down.
Michael Garber
5th Wall – a post production company -
David Battistella
May 23, 2012 at 1:24 amYes, Created in fcpx.
One level down only.
This all seems so basic.David
Lord Herbert
Jeremy Garchow
May 23, 2012 at 3:11 am[David Battistella] “Yes, Created in fcpx.
This all seems so basic. “It’s not this, right?:
https://support.apple.com/kb/TS4169?viewlocale=en_US&locale=en_US
Jeremy
David Battistella
May 23, 2012 at 12:50 pmNope.
It’s not that Jeremy.
David
Lord Herbert
Jeremy Garchow
May 23, 2012 at 2:11 pmSince 10.7.4, if you use FCPX to make a folder and, then quit and reopen, does FCPX hang?
Sorry for all the silly questions. I’m thinking about applying the upgrade, to a clone at least.
David Battistella
May 23, 2012 at 3:04 pmHave not tried that, it seems that it’s a carryover from existing folders.
Lord Herbert
David Battistella
May 23, 2012 at 7:11 pmI will do that but I wonder how the upgrade of the os would affect the permissions on the folder.
I’ll check it though.
David
Lord Herbert
