Activity Forums Adobe After Effects Washed-out, vintage look
  • Washed-out, vintage look
    Posted by Christan David on July 25, 2011 at 5:47 am
    Hello,
    I was wondering if someone can help me with this washed-out, vintage look I’m trying so hard to achieve and unfortunately have no luck. Here is the best example:
    https://vimeo.com/20800127
    I just recently tried color grading in after effects so it’s alright if I don’t achieve the exact look, but well, hopefully I can create something closer to it with someone’s help.
    Thank you very much in advance, any help would be appreciated.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Tudor “ted” jelescu replied 14 years, 9 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    July 25, 2011 at 1:57 pm
    Use Hue/Saturation to take the saturation down a bit. Then Levels to clip the black and white output. A few lens flares flashes on the cuts applied outside the frame with a pink and/or yellow-orange hue can add to the effect (Knoll Lens Flare or Optical Flares).
    Tudor “Ted” Jelescu
    Senior VFX Artist
