Activity Forums Apple Final Cut Pro Legacy washed out image when importing TIFF sequence into FCP
  • washed out image when importing TIFF sequence into FCP
    Posted by Andres D’antonio on February 15, 2012 at 5:13 am
    The company I work for just got Scratch 6.1 for coloring purposes. When we check de colorization final render it looks great. We export this as a TIFF sequence 16 bit, but when we import this sequence into FCP it losses it’s quality, color saturation and looks washed out. We heard FCP only worked with a 2.2 Gamma, so we changed our settings in Scratch from Gamma 1 to Gamma 2.2 and still the same result, just a little bit better. We’ve tried bringing it into AE, export it as a quicktime, but once again when importing it into FCP it looks like a tenth generation vhs. Any ideas what may be wrong?
    Rafael Amador replied 14 years, 7 months ago 4 Members · 3 Replies
  • Michael Gissing
    February 15, 2012 at 5:56 am
    Why not export as quicktime from Scratch? I also don’t think FCP can handle 16 bit TIFFs.
    REC709 is 2.2 gamma so if this is for broadcast then Scratch should be working in that gamma.
  • Erik Lindahl
    February 15, 2012 at 11:55 am
    Image sequence exports from FCP isn’t not recommended. You will get affected or degraded image quality.
  • Rafael Amador
    February 15, 2012 at 5:35 pm
    [Michael Gissing] “I also don’t think FCP can handle 16 bit TIFFs. “
    Right.
    FC will manage it as 8bRGB.
    rafael
    http://www.nagavideo.com
