Activity › Forums › Zaxwerks › Warps within Invigorator 6
  • Warps within Invigorator 6
    Posted by Roger Burton on August 11, 2012 at 3:52 pm
    Hi – I know there’s a Zax warp plugin but in Vers 6 Invig pro there are warp controls that can be applied to a set … very nice but I have created a curved glass “wall” and the lighting hasn’t been affected by the curvature … ie it looks flat … anyone know what I need to try and do to give it some ‘life’ … many thanks
    Roger
    Edward Wu replied 14 years, 1 month ago 2 Members · 3 Replies
  • Roger Burton
    August 11, 2012 at 3:59 pm
    I should have added, I tried using comp lights but it just turned my nice white ‘floor’ black …
  • Edward Wu
    August 14, 2012 at 4:04 pm
    Hi Roger,
    The lighting does update if you warp your objects. If you’re still having problems, please send the project file to me and I will take a look at your setup. Thanks.
    Best,
    Edward
  • Edward Wu
    August 14, 2012 at 4:06 pm
    Hi Roger,
    When you’re using Comp Lights, keep in mind that you may need to add multiple lights to brighten up the scene. By default, Invigorator uses 3 lights so that is why it will be brighter than if you’ve just set up 1 parallel light in After Effects.
    Best,
    Edward
