Activity Forums Adobe After Effects Warping problem with twixtor
  • Warping problem with twixtor
    Posted by Chloe Green on January 6, 2017 at 9:07 pm
    Okay so I managed to solve my problem with the choppy frames but now it’s warping any very fast movements. If it helps, I’ll list everything that I set the effects in twixtor to:
    Display: Twixtor output
    Use GPU: OFF
    Color source: 1. 160428 joshua pretty u fancam (this is the name of the footage i’m using)
    Alt Motion Source: None
    Input fields: None
    Input: Frame rate: 29.970
    Motion vectors: Best
    Image prep: none
    Motion sensitivity: 100
    Plenty memory: Cache last motion? (unchecked)
    Time remap mode: Speed
    Speed: 10.000
    Frame Interpretation: Motion Weighted Blended
    Smart blend: box is checked
    Motion blur compensation: 2.00
    Unless it’s because of something in my settings that isn’t it twixtor, let me know. Any help is appreciated
    Chloe Green replied 9 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
