Activity Forums Adobe After Effects Warping But Kepping The Edge Straight?
  • Warping But Kepping The Edge Straight?
    Posted by Max Jackson on October 24, 2012 at 11:05 pm
    Hi CC,
    I’m working on a comp where I have to bend the contents of a mirror. However, since the mirror has an edge I need to keep the “flag effect” from disconnecting back and forth over the edge.
    I’m currently using FreeForm AE which works great but I can’t seem to control the edge so the edge of the mirror is unnecessarily wobbly.
    What can I do to control that so it looks like the warp from inside is going outside the edge/boundary of the mirror, but the edge stays intact?
    Would really appreciate any suggestion. Thanks!
    Max Jackson replied 13 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Bobotis
    October 24, 2012 at 11:34 pm
    Share the project file with me via Dropbox. Make sure to collect files. Invite me to share the Dropbox folder. Use chris@mettle.com
    I will see what I can do.
    HTH
    Cheers,
    Chris
    mettle.com
  • Angelo Lorenzo
    October 24, 2012 at 11:53 pm
    You might want to check out using a displacement map. You can animate a black and white map for a ripple and alter it so the edges remain still. https://library.creativecow.net/articles/hodgetts_philip/displacement.php
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Max Jackson
    October 25, 2012 at 12:40 am
    Will do, one moment please. 🙂
  • Max Jackson
    October 25, 2012 at 12:42 am
    I looked into that one but I have the mirror at an angle in the room so I would like the warping to come out (which I can accomplish). However, the edge starts floating when I push the depth values. The displacement map stays flat. Looks great, but I need something that pops.
    Thanks for the recommends though! 🙂
  • Max Jackson
    October 25, 2012 at 1:06 am
    Hi Chris,
    I dropboxed the file and bg reference, thanks!
  • Mato Kokotic
    October 25, 2012 at 4:01 pm
    Can you duplicate layer and use Track Matte for reflective surface only? That should leave edges as they are.
  • Max Jackson
    October 25, 2012 at 7:56 pm
    Hi Mato,
    That sounds like a clever idea. You’re probably right. Chris from Mettle was real cool and helped me with my comp so I’m currently adapting the basic layering and lighting strategies he put together and am kind of wrapping my head around that for the meantime.
    I’ll keep that technique in the back of my head in case things get more complex though.
    Thanks again!
