Activity Forums Adobe After Effects Warp Stabilizer VFX
  • Warp Stabilizer VFX
    Posted by Alex Popowych on January 28, 2016 at 3:24 pm
    Hi all,
    So I have been through every VFX tutorial/post I’ve been able to find, but I think that because I’m trying to stabilize action footage it’s a little more complex of a process it’s been difficult to come across exactly the settings I need…I have several clips like the following I need to stabilize:
    https://vimeo.com/153375668
    I have deleted tracking points around only the skier, and also everything but the skier–but AE does not appear to actually be helped by the use of the track points on this clip–in fact once I deleted it seemed like there was no stabilization at all? Which left me with the standard subspace/perspective/scale crop presets, none of which provided a useable result with default settings.
    I guess the solution here is to shoot with a stabilizer rig in the first place, but for those of us who don’t have access is there a workable Warp Stabilizer solution? For this specific subject is there a tracking point delete solution that should work?
    Alex Popowych replied 10 years, 7 months ago 4 Members · 5 Replies
  • Chris Evans
    January 28, 2016 at 3:26 pm
    Video is private and needs a password.
  • Michael Szalapski
    January 28, 2016 at 5:31 pm
    Without seeing the video, I would recommend masking out everything that’s moving (the skier, for example), precomp it (moving everything into the precomp), and then trying the stabilizer on the precomp.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Tudor “ted” jelescu
    January 29, 2016 at 8:57 am
    Before going into masking and deleting track points, I would recommend trying out the Warp Stabilizer in Premiere Pro – I got great results with minor tweaking on the settings.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Alex Popowych
    February 5, 2016 at 1:10 am
    Bumping for password unlock on the video…minor tweaks to default warp settings didn’t work–I always had weird artifacts etc no matter which setting I went with (usually stick with position/scale/rotation). Other thoughts on track point deletion?
  • Alex Popowych
    February 16, 2016 at 10:15 pm
    Bump again for any elaboration on track points as they apply here
