Activity Forums Adobe After Effects Warp Stabilizer Vertical Bounce/Stretch?
  • Warp Stabilizer Vertical Bounce/Stretch?
    Posted by Michael Dominic on June 7, 2018 at 1:47 pm
    I’m stabilizing some footage and I notice that the WS at times compensates by stretching the footage vertically, making it look elastic, I have tried multiple settings but have not found a remedy.
    Michael Dominic replied 8 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Szalapski
    June 7, 2018 at 2:17 pm
    I’ve not noticed it stretching it a whole lot vertically. Can you share an example of what you mean?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Michael Dominic
    June 7, 2018 at 3:00 pm
  • Michael Dominic
    June 7, 2018 at 3:01 pm
    Look at the sky.
  • Richard Garabedain
    June 7, 2018 at 3:02 pm
    set it to fix by position and scale only. sometimes the perspective warp does not work just right
  • Michael Dominic
    June 7, 2018 at 3:48 pm
    There is only the option for “Position, Scale and Rotation”, not only position and scale. I tried it and it causes other oddities.
  • Blaise Douros
    June 7, 2018 at 3:54 pm
    Reduce the amount of stabilization to reduce these jello effects. It defaults to 50%, so dial it back to 15% and then go up from there. You’ll find that you get acceptable results with much less stabilization than you’d think.
  • Michael Dominic
    June 7, 2018 at 4:09 pm
    Thanks.
