Activity › Forums › Adobe After Effects › Warp stabilizer stalls analyzing
Posted by Bart Stevens on December 10, 2013 at 5:08 pmDoes anyone know if there is a limitation with the warp stabilizer that it can only analyze one clip at a time?
If I analyze multiple clips in a single composition, they seem to stall in that stage?Roland R. kahlenberg replied 12 years, 9 months ago 4 Members · 8 Replies -
Mathew Fuller
December 10, 2013 at 5:22 pm -
Bart Stevens
December 10, 2013 at 6:09 pmYes, that is one solution…
My purpose in posting the question is to try get more information.
I didn’t see any documentation regarding this limitation, and have a lot of clips that could use some stabilization.
I’ve read on another thread that there is no “batch mode”, but I wouldn’t define analyzing multiple clips simultaneously as batch mode. -
Todd Kopriva
December 10, 2013 at 6:48 pmWhat version are you using?
After Effects CC (12.1) made the Warp Stabilizer multi-threaded and much faster. It can now handle multiple simultaneous jobs:
https://blogs.adobe.com/aftereffects/2013/09/after-effects-cc-12-1-whats-new-and-changed.html———————————————————————————————————
After Effects team blog
Bart Stevens
December 10, 2013 at 7:31 pmHmmm… yes that’s the version I’m using…
It seems like I’ll set it to analyze, it analyzes for a while, but then quits.
So when I return to the clip, I see the blue bar in the middle saying -Click analyze to begin.
Ram and CPU loads are high but well below maximum. -
December 11, 2013 at 11:54 am[Todd Kopriva] “It can now handle multiple simultaneous jobs:”
Hi Todd, multiple jobs/clips on a single timeline OR individual clips on multiple timelines? I’ve always thought it was the latter and not the former.
Bestest
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI -
Todd Kopriva
December 11, 2013 at 4:33 pmThe Warp Stabilizer effect can analyze footage in the background that is used in different compositions.
Bart Stevens
December 11, 2013 at 10:30 pmThanks for the feedback,
Sounds like results will be better when using the effect in different compositions vs. multiple clips in different compositions.
Thanks again -
December 12, 2013 at 1:01 am[bart stevens] “Sounds like results will be better when using the effect in different compositions vs. multiple clips in different compositions.”
Bart, I believe you meant to write, “results will be better when using the effect on a single clip vs. multiple clips in a single composition.” OR use WS VFX only on single clips. FWIW, it’s the same thing with the 3D Camera Tracker.
HTH
