Activity Forums Adobe After Effects Warp stabilizer How?
  • Warp stabilizer How?
    Posted by Richard Cardonna on June 26, 2012 at 1:09 pm
    dynamic link dcoes not open the clip in a/e. so have to import it. I select warp stabilizer and it goes through the routine after this i try to adjust patameters but cant get it to work. what am I missing. cannot find the start stabilization button.
    Jonny Webb replied 14 years, 2 months ago 3 Members · 2 Replies
  • Daniele Marconcini
    June 26, 2012 at 5:03 pm
    I’d really like to help you but I can’t really understand your english or your problem.
    If you can be more specific I’ll do my best
  • Jonny Webb
    June 27, 2012 at 9:00 am
    open your clip open in AE.
    Either go Window -> Tracker and in the Tracker Panel choose Warp
    or open the Effects and Presets Panel, find Warp, and drag it to your clip.
    Now you will have the effect controls open.
    If “analysing” has not started, you can click “analyse”
    When you change a setting, AE should automatically apply the changes.
    Tip: experiment with only a few seconds of footage – some of the changes require a lot of processing…
    ++ As we’re all here, i guess we’re not all there ++
