Activity › Forums › Adobe After Effects › Warp Stabiliser kills straight RGB alpha output ?!
Posted by Daniel Crooks on October 27, 2013 at 7:01 amI’ve just uncovered something very annoying. I have a precomp with transparent elements but when that precomp has the warp stabiliser applied in another comp the ability to use Straight RGB is removed and I can only render with pre-multiplied alpha. when i view teh Straight RGB channels I get a black (and super aliased) mask. Extremely frustrating ! Am I missing something or is this just how it is ?
Pierre Jasmin replied 12 years, 11 months ago 3 Members · 9 Replies -
Roland R. kahlenberg
October 27, 2013 at 9:56 pmIt’s best to use the Warp Stabilizer at the very start of your workflow. Then ensure that you render out the comp before proceeding with the rest of your workflow.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI -
Daniel Crooks
October 28, 2013 at 12:30 amnormally I would, but in this particular case I can’t.
and given the normal RGB + Alpha works fine, it does seem odd that WARP disables the Straight RGB…
October 28, 2013 at 2:42 amStraight RGB always produces harsh edges AFAICR. I just tried Warp Stabilzier FX (renamed accordingly in AE CC) and the inherent Alpha Channel stayed consistent with expectations – good quality.
HTH
Daniel Crooks
October 28, 2013 at 3:42 amhi Roland and thanks for looking into this.
I’m probably not explaining myself very clearly. when I say Straight RGB I’m meaning outputting a file that contains the alpha channel and clean (non pre-mutliplied) RGB channels. I use the “show rgb channels” button in the comp window – view as “RGB Straight”.
The Warp FVX will output a perfect pre-multiplied alpha but this is no good as I need to the keep the clean (or Straight) RGB info in the file.
for testing create a precomp with a piece of footage in it. Bring that into another comp and apply Warp VFX. now go back to the precomp and apply a mask to the footage. Come back to warp comp and view channels as “Straight RGB”, then turn off the Warp effect and you’ll see what i mean…
October 28, 2013 at 8:17 am[Daniel Crooks] “for testing create a precomp with a piece of footage in it. Bring that into another comp and apply Warp VFX. now go back to the precomp and apply a mask to the footage. Come back to warp comp and view channels as “Straight RGB”, then turn off the Warp effect and you’ll see what i mean…”
Hi Daniel, apologies for not being able to understand/appreciate your issue but my immediate thoughts are that you should commit to the masking prior to applying WS VFX. Your workflow requires the mask to be applied prior to nesting+WS VFX.
I see no rationale, in fact it’s wrong to WS in a higher level comp and then to go back down to the precomp to apply a mask/matte as either one of these affects the pixels that will be used by the WS algorithm. However, I don’t see how such an unwanted workflow will disaffect an inherent Alpha Channel.
Further, I can’t see any issue with what you’ve described, albeit briefly, it all seems like what one would expect with a Straight Alpha. I am also curious as to why you would require WS with footage that contains an Alpha Channel – this is exactly the step where I thought you could re-work your workflow, ie, apply WS followed by some CG to create the Alpha Channel.
Perhaps it’s best that you post a few embedded JPGs – an AEP would be exceptional. I’m also thinking that the issue is not with WS itself but with being able to output a Straight Alpha from AE – for output to an online suite. If so, I’ve passed this ages ago and the solution is beyond my existing memory’s capacity. Again, an AEP and/or screen caps will be good.
Cheers
Daniel Crooks
October 28, 2013 at 10:09 amhey Roland
I hear what your saying about doing the Warp first but in this particular instance I can’t.
I’ve put a small .aep here to illustrate.
and here’s a jpeg, the top row is with the warp effect disabled, and teh bottom row is warp on. Both of the RGBs and the Alphas look identical but see how the far top right still has all the original RGB info where as the bottom right just has black boxes… ugly…
../dc
Daniel Crooks
October 28, 2013 at 12:13 pmah man, it does it with the Pixel Motion Blur effect as well…. I give up.
October 28, 2013 at 6:58 pmDan, see if the info here -> https://www.jaredisham.com/adobe-cs6-part-3-warp-stabilizer/ helps.
Cheers
Pierre Jasmin
November 3, 2013 at 2:55 amIt’s an old time bug in AE, if you perform an analysis you end up using the a different code path than the actual rendering of the effect, where effects before including masks are not applied. For our tools that do things like that, we check if there is an effect applied before us and put up a pop up telling that to user (and the only solution is precompose), but makes me think we should also look if someone has masks applied to warn user.
Pierre
revisionfx.com
