Activity Forums Adobe After Effects Warp shot
  • Graham Quince
    October 23, 2005 at 9:40 am
    sounds to me like you’re almost there, although i’m not sure, as the image link you posted is broken. You’re already nesting your beam layer in another comp, for the displacment to work?
    Which filter are you using to create the ‘beam’? If it’s Beam, then it’s easy. Keyframing either length or time settings will get it moving.
    Hope that helps
    Graham
    http://www.qcit.com
  • Tobsson
    October 23, 2005 at 8:16 pm
    OK, I forgot to make it in another composition and then nest it. I had just taken the picture in the background and keyframed it. Now it works really good. I didn
