Activity Forums Apple Final Cut Pro Legacy Warning – This clip does not match this sequence’s settings
  • Warning – This clip does not match this sequence’s settings
    Posted by Matt Case on July 6, 2007 at 9:10 pm
    While attempting to drag clips into my FCP timeline (after digitizing), FCP warns me that my clip isn’t matching my sequence settings and asks if I want to change my sequence to meet the clip’s format (yes or no).
    When I tell FCP “yes” to changing the sequence settings, the sequence settings get changed to an editing timebase of 29.97 (I originally set my sequence to 23.98 as I shot 24p on an HVX200 using DV tape).
    My complete sequence settings are…
    Frame: 720 x 480/NTSC DV (3:2)
    Aspect Ratio: NTSC – CCIR 601/DV (720 x 480) Anamorphic 16:9
    Editing Timebase: 23.98
    Quicktime Video Settings: DV/DVCPRO – NTSC
    Are these original sequence settings incorrect and should I revert to 29.97 as FCP wants to push me toward or am I okay to continue editing in 23.97 despite the warning FCP is giving me?
    Thanks for any help on this.
    – Matt
    David Roth weiss replied 19 years, 2 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    July 6, 2007 at 10:35 pm
    No. Even though you shot 23.98 on dv, it gets recorded to tape @ 29.97. Unless you remove the pulldown, edit @ 29.97.
    Poke around here for further explanation, it sums it up really well:
    https://www.adamwilt.com/24p/
  • David Roth weiss
    July 6, 2007 at 11:06 pm
    Hey Jeremy,
    Perhaps the “open format timeline” is the single best thing we got in FCS2, simply because a lot of people will actually find out what they’re really working on??? I think I’ll mention that to Tim.
    David
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
