Activity › Forums › Blackmagic Design › Warning! Multibridge extreme!
Posted by Mathias Hekton on March 4, 2008 at 1:41 pmDrivers 6.6.3 do not work with Multibridge Extreme! Do not upgrade from 6.6.2.
Danny Mcdonald replied 18 years, 6 months ago 5 Members · 5 Replies -
Jose Miguel
March 4, 2008 at 2:17 pmI have problem too!
I think that from 6.6.2 to 6.6.3 is a big release, with big problems, very big i think.
My problems, with pal10bit output i have a vertical lines in the output. And audio clicks.
With pal 8 bit output i have problems with audio clicks too but the video is aparently ok…
Jose Miguel.
My computer
MacPro 2.8 (2008)
Multibridge extreme
FCP 6.0.2 -
Kristian Lam
March 5, 2008 at 4:39 amHi Mathias,
What is your system configuration?
We’ve tested this out again after these 2 reports and have not seen anything.
regards
Kristian Lam
Blackmagic Design -
Mathias Hekton
March 5, 2008 at 10:38 amMy configuration is as follows:
FCP: 6.0.2
OSX: 10.4.11
Powermac: 2×3 Ghz Dual Core, 4 GB RAM
QT: 7.3Also it should be noted that the DVI output settings from the Multibrige Extreme is not available in the system preferences when using 6.6.3 drivers.
Jo Hermann
March 5, 2008 at 10:58 amI find the Composite out broken with the new driver, no application (FCP, Shake, Motion, AE) is able to send a picture through it.
The DVI-output-settings vanished from the drop-down-menu
Even if no DVI-Monitor is connected System Preferences>Monitor shows a third screen in HD-dimensions.
10.5.2, all above SW in latest versions
G5 Quad, (grey) Multibridge Extreme 6.6.3Currently I’m considering a rollback on 6.6.2
quick, cheap, good – pick any two
Danny Mcdonald
March 13, 2008 at 1:35 pmIs this the Mathias Heckton that went to Washingtion High??? If so email me at copboy23@hotmail.com as soon as possible. Thanks, Danny …….. if not, sorry to bother you
