Activity Forums Apple Final Cut Pro Legacy warning for Flip4Mac uses; Don’t install QuickTime7.2
  • warning for Flip4Mac uses; Don’t install QuickTime7.2
    Posted by Neil Ryan on July 18, 2007 at 4:51 am
    Telestream have confirmed that when encoding WMV files with uncompressed audio sources after installing QT 7.2, you will receive “Inconsistent Audio Sample Rate” error and the encode will fail. This affects Flip4Mac WMV Studio, Studio Pro, Studio Pro HD versions. They are working to resolve the issue as quickly as possible.
    https://www.flip4mac.com/knowledge/kb_0070.htm
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
    Paul Dickin replied 19 years, 1 month ago 4 Members · 3 Replies
  • Jim Martin
    July 18, 2007 at 2:26 pm
    There are other issue as well (Intel Macs)
    https://docs.info.apple.com/article.html?artnum=306043
    Jim
  • Terry Moore
    July 18, 2007 at 3:54 pm
    After experiencing this problem we found a quick workaround. We’ve only done this one time but it did work.
    Before trying to export a .wmv from your FCP timeline, go to Sequence Settings and change the audio from 48k to 44.1k.
    Then you should be able to export a .wmv file without error.
    No need to export an Mpeg4 and change a bunch of other things. Just change the audio setting of your current sequence and export.
    Good luck.
  • Paul Dickin
    July 18, 2007 at 4:05 pm
    Hi
    Could the procedure that the Apple Tech Note outlines – reinstall the OS X Combo updater then force a prebinding update – be a troubleshooting technique for other inexplicable problems?
